Hi eveyone,
I don’t know if this is the best place to ask this question. I’m developing a new report, and the issue is this.
This is how the datset is defined:
dataset
dataitem(Item;Item)
DataItemTableView=SORTING("No.");
RequestFilterFields = "No.","Inventory Posting Group","Location Filter","Variant Filter" ;
trigger OnPreDataItem()
begin
Location.SETRANGE("Use As In-Transit",FALSE);
DialogWindow.OPEN(Text000 +Text001 +Text002);
//BETEASTD SaveFilters := TRUE;
SaveFilters := FALSE; //BETEASTD
end;
trigger OnAfterGetRecord()
var
ItemVariant: Record 5401;
begin
IF SaveFilters THEN BEGIN
LocationFilter := GETFILTER("Location Filter");
VariantFilter := GETFILTER("Variant Filter");
END;
SETFILTER("Location Filter",LocationFilter);
SETFILTER("Variant Filter",VariantFilter);
Location.SETFILTER(Code,GETFILTER("Location Filter"));
IF ReplacePreviousSKUs THEN BEGIN
StockkeepingUnit.RESET;
StockkeepingUnit.SETRANGE("Item No.","No.");
IF GETFILTER("Variant Filter") <> '' THEN
StockkeepingUnit.SETFILTER("Variant Code",GETFILTER("Variant Filter"));
IF GETFILTER("Location Filter") <> '' THEN
StockkeepingUnit.SETFILTER("Location Code",GETFILTER("Location Filter"));
StockkeepingUnit.DELETEALL;
END;
DialogWindow.UPDATE(1,"No.");
ItemVariant.SETRANGE("Item No.","No.");
ItemVariant.SETFILTER(Code,GETFILTER("Variant Filter"));
CASE TRUE OF
(SKUCreationMethod = SKUCreationMethod::Location) OR
((SKUCreationMethod = SKUCreationMethod::"Location & Variant") AND
(NOT ItemVariant.FIND('-'))):
BEGIN
IF Location.FIND('-') THEN
REPEAT
DialogWindow.UPDATE(2,Location.Code);
SETRANGE("Location Filter",Location.Code);
[b]CreateSKU(Item,Location.Code,'');[/b]
UNTIL Location.NEXT = 0;
END;
(SKUCreationMethod = SKUCreationMethod::Variant) OR
(NOT Location.FIND('-'))):
BEGIN
IF ItemVariant.FIND('-') THEN
REPEAT
DialogWindow.UPDATE(3,ItemVariant.Code);
SETRANGE("Variant Filter",ItemVariant.Code);
[b]CreateSKU(Item,'',ItemVariant.Code);[/b]
UNTIL ItemVariant.NEXT = 0;
END;
(SKUCreationMethod = SKUCreationMethod::"Location & Variant"):
BEGIN
REPEAT
REPEAT
[b] CreateSKU(Item,Location.Code,ItemVariant.Code);[/b]
END;
END;
end;
As you an see, I have 3 calls to the “CreateSKU” procedure, and I have this error:
I’ve defined the procedure inside the requestPage like this:
But it seems I should define it in other place. Any hint?
Thank you very much
