I am gettin an error while we run the report in the object designer.
The error is, “The QC - Incoming/Samples table does not have an active key that starts with the following field or fields : Item No…” . Can i hav a solutoin for this from anyone…
Hi divya,
There could be two reasons,
Your report is using the “QC-Incoming/Samples” dataitem and the key in the DataItemTableView(dataitem->properties->DataitemTableView->Key) is set to a key which either inactive or not present.
Setcurrentkey command has been used for the record "QC-Incoming/Samples " somewhere in your report for the above mentioned key
In either case find out the key used in your report and goto table “QC-Incoming/Samples table” and set the key (view->Keys). If it is already present then check if enabled field is selected.
Hope this helps…
Rgds,
Sid
Hey Sid,
Thank u so much… Its working very fine The error was due to ur first reason.
