Error while upgrading AX 2009 to 2012 R3
I am stuck up with the above error in up gradation process.
please help me out from this error.
Thanks & Regards
Aravind
Please explain to us what exactly you did before you got this error.
We are actually trying to upgrade AX 2009 to AX 2012 and While Upgrading to AX 2012 we have to run the Pre-processing Checklist and while running the Upgrade live preprocessing we are getting this error.
We are Running this process in Source System
We are actually trying to upgrade AX 2009 to AX 2012 and While Upgrading to AX 2012 we have to run the Pre-processing Checklist and while running the Upgrade live preprocessing on source system we are getting this error.
The error says that an attempt to create an DictTable class instance failed. You also know where exactly it is - at line 55 in DimensionAttributeValue.findByDimensionAttributeAndValue(). Go there and look at what table is it about.
If you can’t identify the problem by yourself, you have to give us more information to work with. Start by tell is what table is used at line 55 in findByDimensionAttributeAndValue(). Also tell us how did you setup the source system.
