I am doing upgrade from AX 2009 HF8 to AX 2012 R3 CU9. While running the checklist for Data Upgrade in AX 2012, in “Launch Data Upgrade” step I am getting the following error. Not able to figure out how to resolve it.
Error Details are as below:
"[Microsoft][SQL Server Native Client 11.0][SQL Server]The CREATE UNIQUE INDEX statement terminated
because a duplicate key was found for the object name ‘dbo.DIMENSIONATTRIBUTEVALUESET’ and the
index name ‘I_3260HASHIDX’. The duplicate key value is (5637144576, )."
"Microsoft.Dynamics.Ax.Xpp.ErrorException: Exception of type ‘Microsoft.Dynamics.Ax.Xpp.ErrorException’ was thrown.
at Microsoft.Dynamics.Ax.MSIL.Interop.throwException(Int32 ExceptionValue)
at Microsoft.Dynamics.Ax.MSIL.cqlClassIL.callReturn(Int32 rc, interpret* ip)
at Microsoft.Dynamics.Ax.MSIL.cqlClassIL.Call(IntPtr c, String methodName, Object[] parameters, Type[] types, Object[] varargs, Type[] varargsTypes)
at Microsoft.Dynamics.Ax.Xpp.xApplication.Dbsynchronize(Int32 tableId, Boolean checkAsNeeded, Boolean continueOnError, Boolean showProgress, Object[] checkSyncTables, Boolean createAllIndexes, Boolean useLockForSingleTable)
at Dynamics.Ax.Application.Application.Dbsynchronize(Int32 tableId, Boolean syncAsNeeded, Boolean continueOnError, Boolean showProgress, Object[] checkSyncTables, Boolean createAllIndexes, Boolean useLockForSingleTable, Boolean , Boolean , Boolean , Boolean , Boolean , Boolean , Boolean ) in Application.dbSynchronize.xpp:line 22
at Dynamics.Ax.Application.Application.Dbsynchronize(Int32 tableId, Boolean syncAsNeeded, Boolean continueOnError, Boolean showProgress, Object[] checkSyncTables, Boolean createAllIndexes, Boolean useLockForSingleTable)
at Dynamics.Ax.Application.ReleaseUpdateSync.syncTableUpgrade(Int32 _tableId) in ReleaseUpdateSync.syncTableUpgrade.xpp:line 21
at Dynamics.Ax.Application.ReleaseUpdateBulkCopyExecute.Run() in ReleaseUpdateBulkCopyExecute.run.xpp:line 61
at Dynamics.Ax.Application.BatchRun.runJobStaticCode(Int64 batchId) in BatchRun.runJobStaticCode.xpp:line 54
at Dynamics.Ax.Application.BatchRun.runJobStatic(Int64 batchId) in BatchRun.runJobStatic.xpp:line 13
at BatchRun::runJobStatic(Object[] )
at Microsoft.Dynamics.Ax.Xpp.ReflectionCallHelper.MakeStaticCall(Type type, String MethodName, Object[] parameters)
at BatchIL.taskThreadEntry(Object threadArg)"
When I checked the table DIMENSIONATTRIBUTEVALUESET, I found out that for all the records Hash field is null and that is causing sync errors. The same error I got for DIMENSIONATTRIBUTESET, DIMENSIONATTRIBUTEVALUECOMBINATION AND DIMENSIONATTRIBUTEVALUEGROUP. All the tables have HASH field NULL.
Has anyone come across this error in Data Upgrade???
Would appreciate for quick help as I am stuck up.
Muneeb
