Error while trying to open administration> users> UserProfile veryyyy urgent
My client has moved his database from one environment to other, after that they got the following error
"A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: SQL Network Interfaces, error: 26 - Error Locating Server/Instance Specified) "
Rest of the forms are fine in getting data out. I have checked the code method SIGSigningProvider_SQLServer_Server.hasValidCertificateSQL is giving error at conn.open(). Ax sevice account has the owner rights in the data base.
Go to SQL Server Management then stand on the top of tree(right click) and chose properties
From the left panel in properties screen chose permissions
Check the Axapta Admin User here and give it all permissions…
Regards
M.E
