error while selecting the currency code
Microsoft Dynamics NAV
Attempted to divide by zero.
Page Lookup 97 must close.
OK
I am facing such an error while selection the currency code in sales quote
Is Exchange rate is defined in currency ???
Sir exchange rate is 0.
You need to define the exchange rate in currency before selecting the currency code on transaction.
As well as you can select the exchange rate on transaction also.
Sir i am not getting the exchange rate in Currency table.
Go to currency card and you can find exchange rates button over there.
Sir i am not getting the excahnge rate button in currency card…Sir is there some other place where i can find exchange rate…
If you do not any data in the currency table then you need to create different types of currencies in the currency table you use in you transaction.
Find it in General Ledger Setup → Currency.
