In the classic client on version NAV2009R2 i could run and edit the gantt production shedule in the Cronus database. But when i was trying to save a production shedule (to xml-file) i had this error message:
Could not create an instance of the OLE control or Automation server identified by GUID={F5078F18-C551-11D3-89B9-0000F81FE221}6.0:{88D969C0-F192-11D4-A65F-0040963251E5}:‘Microsoft XML,v6.0’.DOMDocument40. Check that the OLE control or Automation server is correctly installed and registered.
Because this took me too long to solve this issue (and because i want to have i least one hit next time i’ll google my error message[:)]) i will tell how i solvedthis:
On the internet i found some suggestions, but without any result:
reinstall msxml 6.0
register all relevant ocx’s and dll’s
checking clsid’s in registry,…
Then i tried to check if my MSXML worked fine. So i’ll tried to run xml-port 5500 from a different codeunit wich worked fine…
I checked the variables of codeunit 5500 and found a little bug. In the global variables i saw a variable calling xml version 6 and DOM version 6:
I have the same problem, and I wanted to try out your solution.
But when I change ‘Microsoft XML, v6.0’.DOMDocument40’ to ‘Microsoft XML, v6.0’.DOMDocument60’ and want to save it, I get the next error message:
Could not load the selected type library.
Do you have any idea what can be the problem? Maybe you had the same?
