I am created an ssrs report with Ax query and i seen the preview every thing is fine. I am trying to run this report in
sql server Reporting services browser. It throws me fallowing error.
The DefaultValue expression for the report parameter ‘AX_CompanyName’ contains an error:
Dynamics Adapter LogonAs failed. (rsRuntimeErrorInExpression)
You need to execute following steps-
1)For SSRS 2008 the Business Connector proxy account is required to be the SSRS service account through Reporting Services Configuration Manager.
2)Remove the SSRS execution account through Reporting Services Configuration Manager.
3)Restart the AOS and the Reporting Server.
hi,
im having the same issue. but the given solution is not working. is there any other workaround available?
thanks
