shon4z
1
Hi Frnz,
Over here, when am trying to post-recieve a transfer order , am getting error
" The transactions on voucher 54868_100 do not balance as per 05/03/2011. (Company currency: 0.00 - secondary currency: 0.00)
Error in unit of amount in currency INR. Must be rounded to 0.01. "
In partciular out of 10 items in lines… this error is generated for ony 6 items…
i have no clue regarding this.
am i missing something.
Please help.
Thanks in advance and all suggestions appreciated.
The might be a rounding off problem.
IN GL-> Exchange rate change the general round off to 0.01 for the INR currency and try to post it.
shon4z
3
Kranthi-- I did that before and tried redoing the action
but in vain – same error!!
is this a bug in standard??
shon4z
4
I would really appreciate/thankful… if some1 could come up with a solution/ suggestions please.
heylin
5
validate your entries first
HI Shon,
I may be beacuase of no secondary currency , need to setup the secondary currency…
Naresh Kolli
shon4z
7
Naresh-- i would definitely try that option of secondary currency…
But how does it impact in system??Taking into consideration- complete application…
shon4z
8
well…
i solved the problem…anyways!!
steps i did: As suggested by Kranthi made the round off to 0.01 all fields in Exchange rates OF GL Setup
but that all alone dint solved the problem
When i did AR- Setup-CleanUp-Purchase clean Up-
It worked…!!
Now no error!!
But i have question… the system and stock transfer was working fine till then, all of a sudden this came into picture…
any one put ur thought and suggest me the reason …why nd how??
Apprecate the help.
hi
//When i did AR- Setup-CleanUp-Purchase clean Up-
is it correct ???
pls tell the correct tha path, am also facing the same solution
thanx you in advance dude
