i have imported items in ‘InventJournalTrans’ & ‘invent journal table’,when i try to
post these items its giving error says that,“Can’t receive quantity
1 ,because inventory transaction with status Ordered,arrived or
registered are insufficient”.
But when i click validate button it didn’t give any error.
Kindky advice me how to solve the error/
You presumably imported data into the movement journal then? This was not manually keyed?
yes, i have imported the excel template,validated (journal is Ok), but while posting got the error.
Have you also imported inventtransid and inventdim id with the data??
You did not import the required tables, when you manually write a line into the movement journal this also created inventory transactions etc. You need to ensure your routine creates these transactions as well.
