You should really try to google or bing this - there a tons of explainations of what the problem and solution could be. It is hard to give you more information because you have not stated your SQL Server version or your Dynamics NAV version.
If you want faster answers you should try to add as much information as possible.
One problem could be that you are about to run out of space on either your database or your harddrive that holds the temporary ZUP-file but it could also totally relate to a SQL issue - but again it depends on your NAV and SQL.
