Error while opening CustInvoiceJournal Form through SSRS Report
Hi Friends,
I am working in dynamics ax2012 R3. while running ssrs report i want to open the form. Form name is CustInvoiceJournal. i used below code in process report.
form = new Form();
args = new Args(formStr(CustInvoiceJournal));
// Create the run-time form.
formRun = new FormRun(args);
// Return an object for the first data source,
// and then display a query form.
formRun.init();
formdatasource = formRun.dataSource(1);
formDataSource.query(query);
formRun.run();
formRun.detach();
it throws errors like
(S)\Classes\CW_SalesBookReport\processReport - line 151
(S)\Classes\SrsReportProviderQueryBuilder\initialize - line 59
(S)\Jobs\
i can’t find exact mistake in that line . can you help me out this error?
Thanks In Advance…
Hi Saravanaa,
pass the recid in find method and and run the job and see the form will open .
same way you can call the form in process report but i have bit confuse about your requirement, why u want to open the form at the time of report open,
i hope the below code will help u .
static void custInvoicejournalFormOpen()
Args args = new Args();
args.record(CustInvoiceJour::findRecId(5637166334));
new MenuFunction(MenuItemDisplayStr(CustInvoiceJournal),MenuItemType::Display).run(Args);
