Dear all
I followed all the reuired steps in
Team Server (ID Server) Setup Whitepaper for Microsoft Dynamics AX 2009
I am using mssql(2005) and Vss(2005)
When trying to install Team Server from the EXE, I go through the wizard smoothly until I click “Install” and while installing,
I get an error that says: =========================================
Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
Cannot drop database “AXTS” because it is currently in use
If I choose continue, it looks like the installation hangs. I waited an hour or so before killing the process. If I choose quit, it just stops.
Please help me to resolve this issue.
