While installing AX2012 server, I am getting following error:
2012-03-13 12:57:32Z Cannot find the object ‘UTILIDELEMENTS’, because it does not exist or you do not have permission.
2012-03-13 12:57:32Z Cannot find the object ‘UTILELEMENTS’, because it does not exist or you do not have permission.
2012-03-13 12:57:32Z Cannot find the object ‘UTILMODELS’, because it does not exist or you do not have permission.
2012-03-13 12:57:32Z ******************************************************************************************************
2012-03-13 12:57:32Z Common Property Install Path set to ‘C:\Program Files\Microsoft Dynamics AX\60’.
2012-03-13 12:57:32Z Installation Path retrieved from registry. Value: 'C:\Program Files\Microsoft Dynamics AX\60’
2012-03-13 12:57:32Z Setting up rights for the AOS service account ‘ibrodm\vn.it04’ to access the application files at: C:\Program Files\Microsoft Dynamics AX\60\Server\AX1\bin\Application
2012-03-13 12:57:32Z Component installation task stopped due to an error.
My working environment: Windows 2008, SQL server denali
I use an account as admin right to access server
Please help me if any solution
Thanks in advance
