Error while Importing Budgets!
Hello Guru’s,
I need some help with Standard Navision Budgets.
Data base: Navision 5.0 (SP1)
I am trying to upload budgets, so I thought i did test it out first. I created a mock budgets for 2 G/L accounts and exported out. It worked fine.
Now, when I want to import the excel sheet back into Navision, I get the below error message. I have no clue on this error.
G/L accounts have not been found in the excel work sheet
Please be noted that i created the values for only 1 or 2 G/L accounts in the budget and then exported out.
Your help is much appreciated!!
Jack
wat r all the fields added in excel sheet…
Hi Jack,
I suspect that you have deleted the header row in Excel. Export a sample and make sure you sheet has the same format including headers.
