Error While Import text file Via Data port
Hi All
I;m getting an error message while import a text file Via data port.Pleas reffer the attache picture
Help Me
Marshal.J
i did as you asked (imported text via dataport) and i got my files imported and exported properly. did you check the coding as it is said there? what type of filtering are you using?
And Happy hitting century:)[Y]
Thanks Shona
There is no filters in and there is no piece of code in the data port.
Jerome Marshal.J
Hi Marshal,
It seems that you are trying to modify or insert records while a table is still locked, could you paste your code here for us to see better where is the issue…
My pleasure:)
so are you saying there is no code written by you? what table are you trying to import?
