Error while getting recepit lines
When I’m trying to get Receipt Lines (into invoice) I get a message ‘Get Receipt Lines’ cannot close because the system is currently working’ and then appears an error ‘The user-defined C/AL function that takes 3 parameters, was called with 2 parameters.’ I doesn’t changed the code of this process so I don’t know why is appearing this error.
Anyone got some idea?
Thanks.
Which version are you using?
Are the PO’s existing in Purchase Line table or deleted?
I’m using Nav 6.0 R2
No, they’re deleted.
This is the reason for this error…
