vikas99
1
Hi Folks,
I am getting the following error while deleting a record directly from a cust table form .
Cannot edit a record in Customer table(CustTable).
The Values displayed in the form are not current , so an update or deletion cannnot be made .
To view the current values, Click Restore or press CTRL+F5.
I am able to delete a record from the job.
I am receiving the same error inspite of refreshing and synchronozing the tables and forms.
Any kind of help is highly appreciable.
Vikas Mehta.
kranthi
2
What is your code to delete the record?
vikas99
3
delete_from CUSTTABLE
where CUSTTABLE.CUSTID == 1100
Harish
4
After deleting the record, are you calling research() method like this -
custTable_ds().research()
vikas99
5
no nothing like that
just deleted that record no refresh nothing
but i want to delete it from the form end not from the job
Harish
6
If you are not doing it, then write the code mentioned in my post above.
To understand what that line does, refer here - http://kashperuk.blogspot.com/2010/03/tutorial-reread-refresh-research.html
