Error while creating Purchase Order - WHSAutoCreateLoadLine incorrectly called
AX gives “Function WHSAutoCreateLoadLine::newFromSourceLineTableBuffer has been incorrectly called” error while creating a purchase order. I tried Compile and Forward WHSAutoCreateLoadLine class from AOT and compiled AX application and CIL compile and still getting the same error. 4213.10-15-2014 3-49-01 PM.jpg
You get this error if you call newFromSourceLineTableBuffer() with a buffer which is not supported. What type of table is used there when it fails? Are you developing something custom there?
It is a out of box installation with no customization. We imported the Vendor list and compiled the application. When we raise a PO, getting this error.
What’s the answer to “what type of table is used there when it fails”? Debug the method to find it.
HI
I have resolved the above issue, on resetting the cache data in AOT.
  1. Reset usage data.
  2. Remove log files from user.
  3. Refresh the cache data. AOT–>Tools–>Cache → Refresh all nodes.
It is working fine.
