I am programmatically trying to create POs in bulk, to accomplish that I have put the PO creation code in a loop. The code works perfectly for the first iteration of the loop, however gives error “Order number cannot be changed” in the second iteration. I’ve taken care of incrementing the PO number and all standard precautions are implemented. Can anyone suggest the reason behind the error.
I’m working on Ax 2009 and the PO creation code got from:
