We have implemented the web service to get exchange rages from web. In-order to achieve this we added dll reference in AX and called the dll reference in x++ by using batch frame work.
We are able to get the exchange with out batch but facing issue when executed in batch process and getting socket error.
Can any one suggest us steps to trouble shoot the issue, Exactly where we have to provide access particulate URL and what permissions.
ERROR as below :-
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. —> System.Net.WebException: Unable to connect to the remote server —> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 191..*.:80
at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress)
at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception)
— End of inner exception stack trace —
at System.Net.WebClient.DownloadDataInternal(Uri address, WebRequest& request)
at System.Net.WebClient.DownloadString(Uri address)
at TestGetExchangeRate.TestGetExchangeRate.fnGetExchangeRate(String sPath)
at Dynamics.Ax.Application.TestRetrieveExchRatesWeb.Run() in TestRetrieveExchRatesWeb.run.xpp:line 99
Krishna
