hello Frnds…
I have made an exe file that receive an Argument as SaleOrderNo., I have checked if from RUN command it is running fine…but when I call in from Navision through Shell command it is giving me error which is below:
The FIle Name “\FilePath\folder1\Folder2\MailFIle.exe SOF/S/00012” contains a character that cannot be used.
CHeck the file name. You can find additional information about file names in the documentation for your
operating system.
Error is coming when I am calling exe file with parameter …if I call this file without any parameter it’s calling fine from Navision too…I am not getting what wrong I am doing here…
I am calling this file in this way:
SHELL(’\tally_server\AutoReports\Nav\MailingComponants.exe ’ + “No.”);
pls suggest…
