Dear All,
I got that error when receiving a shipped transfer order I searched for the error some people suggest to check or uncheck compile CIL and use a different user I tested both with no cigar. There is no customization in the form The stack trace is as the following:
Error executing code: Overflow in internal run stack.
Stack trace
(S)\Classes\SysCountryRegionCode\countryInfo - line 16
(S)\Classes\SysCountryRegionCode\isLegalEntityInCountryRegion - line 16
(S)\Classes\InventMovement\new - line 15
(S)\Classes\InventMov_Transfer\new - line 8
(S)\Classes\InventMov_TransferFrom\newFromInventTransferLine - line 17
(S)\Classes\InventMovement\constructNoThrow - line 263
(S)\Classes\InventMovement\construct - line 6
(S)\Data Dictionary\Tables\InventTransOrigin\Methods\inventMovement - line 114
(S)\Data Dictionary\Tables\InventTrans\Methods\inventMovement - line 41
(S)\Classes\InventUpdate\updateTransDimTransferReceipt - line 34
(S)\Classes\InventUpdate\updateDimReserveChange - line 82
(S)\Classes\InventUpdate\writeInventTrans - line 100
(S)\Classes\InventUpdate\updateTransDimReceipt - line 22
(S)\Classes\InventUpdate\updateTransDimTransferReceipt - line 105
(S)\Classes\InventUpdate\updateDimReservePhysical - line 126
(S)\Classes\InventUpdate\writeInventTrans - line 123
(S)\Classes\InventUpdate\writeInventTransAutoDim - line 274
(S)\Classes\InventUpd_Physical\updatePhysicalReceipt - line 160
(S)\Classes\InventUpd_Physical\updateNow - line 37
(S)\Classes\InventUpd_Financial\updateNow - line 44
(S)\Classes\InventTransferUpdReceive\updateInventTransferLine - line 522
(S)\Classes\InventTransferUpd\updateLines - line 49
(S)\Classes\InventTransferUpd\updateInventTransferOrder - line 13
(S)\Classes\InventTransferUpd\run - line 23
(S)\Classes\InventTransferUpdReceive\run - line 8
(S)\Classes\InventTransferMultiReceive\runUpdate - line 6
(S)\Classes\InventTransferMulti\run - line 33
(S)\Classes\RunBaseMultiParm\runOnServerInternal - line 31
(C)\Classes\RunBaseMultiParm\runOnServer - line 8
(C)\Classes\InventTransferMultiReceive\main - line 37
(C)\Classes\FormFunctionButtonControl\Clicked
