This errormessage came “This automationvariabel has not been initiated…” så på
Could it be that you forgot to CREATE the variable? CREATE(MyAutomationVariable); //… code that uses the variable goes here… CLEAR(MyAutomationVariable); Kind regards, Jan Hoek Weha Automatisering BV Woerden - The Netherlands
A selection appears Where you can choose a scanner, when You trie to choose, nothing happens!!!
