Error when creat warehouse in Dynamics AX 2012 R3
When I create a warehouse, I select “Use warehouse management processed” check box. I want to create a location and cycle counting setup.
And I see this error "Warehouse ABC uses warehouse management processes that are enabled by the Warehouse and Transportation management configuration key, but the Warehouse management II configuration key is also enabled. This combination is not supported. Choose and enable only one configuration key"
Can you help me to fix it.
Thank in advance.
