IDispatch error #3119: Violation of PRIMARY KEY constraint ‘I_175ITEMIDX’. Cannot insert duplicate key in object ‘dbo.INVENTTABLE’.
IDispatch error #3119: Violation of PRIMARY KEY constraint ‘I_20123ITEMIDX’. Cannot insert duplicate key in object ‘dbo.RBOINVENTTABLE’.
I am doing some modification on Item Table (creating new items) and then trying to send the record through A-1040 job .System is able to read the record but failed to write the same on POS data base and error is appearing as mentioned in the above lines. coulde you give me any idea .
thanks and regards
kittu
