Error Type:(0x800C0008)/Factory/store.vbs, line 19
I have tried to install Navision User Portal. Digital dashbord runs well, also SQL server, but Navision UP gives following message: Error Type: (0x800C0008) /Factory/store.vbs, line 1968 Could anybody help me? -------------------------- moved from Technical Forum Edited by - rmotzer on 2001 Nov 11 15:47:37
The problem are in this function in Store.vbs: Line 1968 äre bolded. '---------------------------------------------------------------------- ’ StoreDashboardExists ’ ’ fs addition ’ Returns true if varDashboardID exists, otherwise returns false. '---------------------------------------------------------------------- Function StoreDashboardExists(varDashboardID) Dim xmlTemp, xmlhttp set xmlTemp=Server.CreateObject(“Microsoft.XMLDOM”) set xmlhttp=Server.CreateObject(“Microsoft.XMLHTTP”) xmlTemp.loadXML “<?xml version=""1.0""?><d:propfind xmlns:d=”“DAV:”"><d:prop><d:contentclass/></d:prop></d:propfind>" xmlhttp.open “PROPFIND”, varDashboardID, 0 xmlhttp.setRequestHeader “depth”, “0” xmlhttp.send xmlTemp If Len(xmlhttp.responseXML.xml)=0 Then StoreDashboardExists=False Else StoreDashboardExists=True End If End Function Maybe this can help you out with your problem… I Think it could be an object that is not correct registraded at your server. Per.Bay@navigera.com Product Manager www.navigera.com
quote:
Originally posted by Per Bay: The problem are in this function in Store.vbs: Line 1968 äre bolded. '---------------------------------------------------------------------- ’ StoreDashboardExists ’ ’ fs addition ’ Returns true if varDashboardID exists, otherwise returns false. '---------------------------------------------------------------------- Function StoreDashboardExists(varDashboardID) Dim xmlTemp, xmlhttp set xmlTemp=Server.CreateObject(“Microsoft.XMLDOM”) set xmlhttp=Server.CreateObject(“Microsoft.XMLHTTP”) xmlTemp.loadXML “<?xml version=""1.0""?><d:propfind xmlns:d=”“DAV:”“><d:prop><d:contentclass/></d:prop></d:propfind>” xmlhttp.open “PROPFIND”, varDashboardID, 0 xmlhttp.setRequestHeader “depth”, “0” xmlhttp.send xmlTemp If Len(xmlhttp.responseXML.xml)=0 Then StoreDashboardExists=False Else StoreDashboardExists=True End If End Function Maybe this can help you out with your problem… I Think it could be an object that is not correct registraded at your server. Per.Bay@navigera.com Product Manager www.navigera.com
