Error thows while doing Production Ended Process
Could anybody update me regarding this error, that is when i doing production ended process.The following error occurs " Calculating BOM Consumption". All the other status of production order can be updated well.
This error is due to what?
Any setup is required for this?
Do update me regarding this.
Thanks and regards,
D. Praveen Kumar.
What is the actual error?
What atages are you going thorugh prior to ending? When are you flushing? Tell us what it is doing correctly - RAF, Picking and Route Journals?
The error occurs when i doing Ended (Production → Common Forms → Production Order Details → Update Button —> End) process of a production order.
Before ending the Production process, i am updating the following status - Created, Estimated, Scheduled , Released, Started, Report As Finsihed .
While updating Started status of a Production Order - i am posting picking list journal.
Once Picking list journal is posted, i am updating Report as Finished status.
After RAF updation, when i am doing Ended process, i am getting the following error (i.e.) "Calculating BOM Consumption"
Kindly do update me regarding this.
Thanks and regards,
D. Praveen Kumar.
Can you post a screenshot of the error?
Any modifications in produciton?
The following error i am getting while ending the production process.
And no modifications in production module.
Production: PRD_00000009
Calculating BOM consumption
Error executing code: InventMovement (object) has no valid runable code in method ‘updateLedgerAdjust’.
(S)\Classes\InventMovement\updateLedgerAdjust
(S)\Classes\InventUpd_Financial\updateFinancialIssue - line 75
(S)\Classes\InventUpd_Financial\updateNow - line 68
(S)\Classes\ProdUpdHistoricalCost\updateBOMConsumption - line 31
(S)\Classes\ProdUpdHistoricalCost\run - line 41
(S)\Classes\ProdTableType\runHistoricalCost - line 8
(S)\Classes\ProdStatusType_ReportedFinished\runHistoricalCost - line 11
(S)\Classes\ProdMultiHistoricalCost\run - line 17
(C)\Classes\ProdMultiHistoricalCost\main - line 14
(C)\Classes\FormFunctionButtonControl\Clicked
(C)\Classes\FormFunctionButtonControl\Clicked - line 19
(C)\Classes\FormMenuButtonControl\Clicked
(C)\Classes\FormMenuButtonControl\Clicked - line 37
Thanks and regards,
D. Praveen Kumar.
It indicates that there are some errors in the class - try to compile the class InventMovement - to find out the errors…
Hi sir Kranti, the error in the class states: “The new method of a derived class does not call super().”. How can we troubleshoot this error?
thanks
D. Praveen Kumar,
Hi I also experienced this error, I just want to ask how did you troubleshoot this error?
thanks
Jems
Add breakpoint to Classes > Info > add method and run your process. By doing so, it should be easy for a Developer to understand/resolve the issue.
