error-select a dimension value code for dimension code branch
My client has problem posting a sales invoice
Even though the dimension value is set to the invoice head and lines the error
-"select a dimension value code for dimension code branch " is still showing.
Please HELP!
Is there any customization ?
Any account is having Branch code mandatory which is used in Setups ?
You can also check whether it is trying to post any rounding line and rounding account didnt have branch dimension set…
Recently I have updated fields PIT(price inclusive o tax)-true, PIT structure,Unit price on each item cards. Due to this when posting Sales Invoice with that item it showing error " Select a dimension value code for dimension code branch" . but when i remove PIT(false), PIT structure for that item then invoice is posted .
help?
Cant you wait?
Best is Activate Debugger and check…
You have to check the sale header and sale line dimension. Also check ctrl+shift+D key for valid dimensions.
If any dimension not exists then put that absence one in the dimension code values.
