after adding some new fields to the tmptable and modifying the SalesInvoice report, i get this strange
error when i post the invoice - returned from the report framework. The report is created and printed
and the sales order is invoiced, but what does this errorcode mean - and how can i remove it:
"The dataset ‘SalesInvoiceDS’ contains a definition for the Field ‘ConfigIdFlag1’. This field is missing from the returned result set from the data source. "
The dataset ‘SalesInvoiceDS’ contains a definition for the Field ‘ConfigIdFlag11’. This field is missing from the returned result set from the data source"
I did not remove these fields in the report, and I also did a refresh on the datasets in Visual Studio, but I still get the
error.
Jesper
