Error re: autosplitkey when entering a new comment line between two existing ones
NF 2.01B S&R > Customer > Comment Sheet Entering a new comment line between two existing ones generates an error message re: autosplit key. Dropping the Line No. field on the Comment Sheet form showed the first two line no’s as 1 and 2, since a line no has to be an integer , the system doesnt allow a new line to be entered between these two. Tried renaming zup file, autosplitkey is set to yes !! ???
Gemma The line No.'s should be 10000 and 20000 have you had work done with the comments tables? Mr David Cox MindSource (UK) Limited Navision Solutions Partner Email: david@mindsource.co.uk Web: www.mindsource.co.uk
Dave, No work has been done on the comments table. The problem occurs intermittently and sometimes corrects itself???
If the two questions you have posted relate to the same Database and you have applied all Service Packs, the Only path I can think of is to Backup and Restore the database to a different PC try to reproduce the errors, if unable to reproduce them, then it could be the binaries Check the Hard Disk if ok then reinstall Navision and reapply service packs! any other Idea’s anyone? Mr David Cox MindSource (UK) Limited Navision Solutions Partner Email: david@mindsource.co.uk Web: www.mindsource.co.uk
This CAN be reproduced so I think it is a bug in Navison (2.00a US). Try this to reproduce. Add a line to the comment table for a customer and set “Code” field to ‘ITEMNOTE’. Next add another comment with “Code” field blank. (Note the table resorting itself). Next add another comment with “Code” field blank. Navision errors with a comment line already exists error. It is because the primary key is “Table Name” ,“No.”, Code, “Line No.”. Paul Christensen Senior Appl./Network Analyst Moss Motrs, Ltd. 800.235.6954 x3210
Paul Gemma has the problem at Form level not at the Table level the Code field is not on the form, as you cannot have a blank customer, you will not reproduce your observation with normal proccesing of Data. The Code field on the table is for Ship-to Address IE. Customer,CLINTON,DC,10000 Overview of the AutoSplitKey: The AutoSplitKey property is not availiable at Table level only at Form Level that is why you was able to create your error. when the AutoSplitKey is selected on the form properties Navision will autofill the “Line No.” field starting at 10000 and the incrementing by 10000 so the second line would be 20000. if you enter a line between, the AutoSplitKey function divides the two “Line No.” fields to create a 15000 “Line No.” Primary Key Code “Line No.” 1000 10000 1000 15000 < Inserted Record 1000 20000 Gemma’s problem is that Navision created lines with “Line No.”'s 1 and 2 so the AutoSplitKey could not Insert a record between! Mr David Cox MindSource (UK) Limited Navision Solutions Partner Email: david@mindsource.co.uk Web: www.mindsource.co.uk Edited by - David Cox on 8/11/00 8:33:20 AM
Gemma’s problem is that Navision created lines with > “Line No.”'s 1 and 2 so the AutoSplitKey could not > Insert a record between! Are you certain that these records were not generated by a data conversion or some means other than data entry via the Navision form? -jp
JP, These customer comments were created purely by data entry. Gemma
Perhaps the field “Line no.” has been on the form at one time, and the user has entered the line no. ?
I am the user concerned and can be certain that no manual entering of field number is possible, (for a user making general data entry).
Remember also that if you view the data through a form with AutoSplitKey set to yes, then you can cut and paste the lines of data back into the same rows. Navision will automatically increment each line/row by 10000. Make sure to select the rows by using the grey bar to the left of the rows for this to work. As far as why the records were numbered 1 and 2, you will need to determine how the records were entered, and if they had been renumbered. If they were inserted by a code rather than by a user, investigate the section of code that determines the number for the record to be inserted.
When you insert a new line in comments with F3 key, navision inserts a new line. If you are with line 10000, navision inserts line 5000, 2500, 1250, 625, 312, 156, … and continuing to line 1. Therefore, Navision makes an error, because you are between line 2 and 1. You can go back to the beginning cutting and pasting all comment lines. Navision renumbers lines with 10000, 20000 , …, and you can continue working normally.
Can one instruct NF to renumber - apart from copy/paste? Edited by - HenrikKraglund on 8/29/00 1:12:44 AM
You are using primary key.
reply to HenrikKraglund >>Can one instruct NF to renumber - apart from copy/paste? No, not in standard NF You need to get your NSC to make a small function to renumber/copy comments. Or if you are a super user with access to the object designer, select and run table 97 “Comment Line” and locate the comment line you want to renumber. Change “Line No.” to the desired number and select the following line. You will be prompted with “Do you want to rename the record” choose yes and the renumbering is complete.
