I have a SSRS Report using RDP(temporary table). i use the Query Attribute [SRSReportQueryAttribute(queryStr(PlatformQuery))] and have processReport() to generate dataset for the report.
I have this error arise in the prePromptModifyContract(),
Query qry = this.getFirstQuery();
QueryBuildDataSource queryBuildDataSource;
QueryBuildRange qbrRequestNumber;
platform = args.record();
info(platform.Plat_ID);
qry.dataSourceTable(tableNum(Platform_Detail)).clearRanges();//// error thrown here by qry
queryBuildDataSource = qry.dataSourceTable(tableNum(Platform_Detail));
qbrRequestNumber = queryBuildDataSource.addRange(fieldNum(Platform_Detail,Plat_ID));
I am using AX 2012 R3, reply if u have any suggestions…
Thank u…
If I understand the code correctly, the problem is already on the first line (this.getFirstQuery() doesn’t return any query), correct?
(Question moved from the Technical forum.)
Thanks for reply,
I think the problem is, I have added the QueryAttribute after the report is deployed. it didn’t work after re-deployment also. So, i have to repeat the step to create the SSRS report from the sketch, Now it works fine.
Does the SSRS report needs to be re-created from the scratch when QueryAttrib is added before deploying it to AOT? Please advise. Thanks
You don’t have to. But please explain your case in detail (may be in a separate post). The one you are trying to reply is two year old post.
Actually, I have the same error.
When I run the report, it says: Error: Query object not initialized. And it points to prePromptModifyContract() method.
have you tried by refreshing the data set on the report?
