When I try to post an Inventory Movement created from an Internal Movement, I get the following error:
Item tracking defined for the source line accounts for more than the quantity you have entered
The problem seems to be that the process that creates the Inventory Movement from the Internal Movement does not populate information related to item tracking (in my case Lot No.).
Any workarrounds? (I have check al CU logs and didnt find any solving the issue).
I am using original 2016 without any CU.
