ERROR Page 50 Purchase Order contains several action with the same ID
What is this error?
page 50 Purchase Order contains several action with the same ID -113. Redesign the page to remove duplicate ACTIONS ID
Please help me!!! I can’t make a new PO
DYNAMICS NAVIGATE 2016
Hi. Try compiling the object to confirm an issue with the object. Then select object, click design and View Page Actions. Look at ID of each and amend / remove duplicate id 113.
Or, of course, assuming this has been caused by a bespoke change restore the back up of this object that was taken pre change.
Neil
Go to the properties of each action and make sure that they all have diffrent IDs. This happens due to the fact that there are 2 action which have the same Id. make sure that you though each action coz navision wonot tell you which action has this issue.
Regards :slight_smile:
Remove the same id by going in action properties and compile the object
You can try right-click the ribbon of PO>> choose ‘Customize Ribbon’ >> then click ‘Restore Default’ >> then try create new PO again.
Thanks.
