The metadata of table 5200 is invalid is the message I get
when I try to run the employee table.
Can anyone please help me out on what the problem might be.
Thanks.
Thanks.
Did you try by compiling table 5200?
if possible compile all objects and restart the service.
You can try with different methods:
Deleting metadata of table 5200 from Object Metadata table and recompile it
In development environment running Tools → Build Server Application Objects and check for any errors.
I tried all that but it still gives me the same message as before.
