2185.SSRS error.docx (91.7 KB)
Hi All
I am Created a query in Ax 2012 AOT and called that query in Visual Studio 2012 but when I am doing the design then it showing Visual Studio error :Attempt By method 'Dynamics.Ax.Application.AifUserSession.Getaifcurrencyinfo() to access Method Dynamics.Ax.Application.AifCurrencyInfo.Parmdescription(Sysem.string,Boolean),failed .
Only it is showing in design time I also seen those class in my Ax 2012 AOT ,I hope there is no problem . so kindly help me
Regard
Sumit
8688.Error Base report Data.docx (39.6 KB) .
Hi
All my Base report on development environment are sowing Label rather to any name.
Also my Ax 2012 ssrs Report throwing error at design time , and not deploying but if same query and same stuff if I am doing on my test it working fine .
when I am trying to design any Ax 2012 SSRS report in my visual studio at design time the below Error showing:
Kindly help me .
Regards
Sumit
Hi Sumit,
Can you check the Inbound port form whether the default userseesionservice and shareddservice and aifclient service is activated or not? if not then try to activate and test the design part in VS… I am not sure but I hope it will help you…
Abbas
