Error message:
Unhandled exception has occurred in a component in your application. IF you click continue, the application will ignore this error and attempts to continue.
Could not find any resources appropriate for the specified culture or the neutral culture. Make sure “Errors.resources” was correctly embedded or linked into assembly “Microsoft.Dynamics.MsiManagedLib” at compile time, or that all the satellite assemblies required are loadable and fully signed.
This error comes while I am trying to validate system requirements under AX2012 installation on selecting SERVER component AOS. If I will not select this component for installation, then it works.
Additionally if we are use same folder of AX2012 setup to install on some other machine, then it has worked (Abel to install two instances with no problem).
