I am a new AX2012 developer. I did the AX2012 report. I did the report with the temp table (InMemory) initially and deployed already. After that, I added the new fields into the temp table and modified the report. When I re-deploy the report again errors occurred.
The error which will show as below:
Unable to add the table field ‘new_field’ to the query source ‘temp_table’. Table field ‘new_field’ does not exist on table ‘temp_table’.
I checked the new fields have already been added into the temp table, therefore I tried to did the following, but the error still pop up
1) Generate the incremental CIL
2) Generate the FULL CIL
3) Synchronize the temp table
4) Synchronize the Data Dictionary
5) Reset the "Usage Date"
6) Delete the AUC file in the AppData
PLEASE TELL ME WHAT CAN I DO NOW.
