i need to upload/download file from another folder (same domain). to do this i write below class and when i run it, ‘error Object ‘CLRObject’ could not be created’ prompt. After debug the program i able to locate the error come from below line
‘directoryInfo = new System.IO.DirectoryInfo(strFilePath);’
may i ask, is it because AX not allowed me to use IO service?
and anyone can help me on this?
Class
static Container ConnectionTest()
System.IO.DirectoryInfo directoryInfo;
System.IO.FileInfo fileInfo;
System.Type sysType;
System.Array arrFiles;
FilePath strFilePath;
FileIOPermission filePermission;
InteropPermission interopPermission;
Set permissionSet;
int intPathCnt,
intFileCnt,
intTotalFiles;
container conSourceFiles,
conFiles;
Filename strFullFileName,
strFileName;
#IDS_FA_Integration_Mcr
interopPermission = new InteropPermission(InteropKind::ClrInterop);
//source path
conSourceFiles = [#AcquisitionNet];
for (intPathCnt = 1; intPathCnt <= conLen(conSourceFiles); intPathCnt++)
strFilePath = conPeek(conSourceFiles, intPathCnt);
filePermission = new FileIOPermission(strFilePath, “R”);
permissionSet = new Set(Types::Class);
permissionSet.add(interopPermission);
permissionSet.add(filePermission);
CodeAccessPermission::assertMultiple(permissionSet);
sysType = System.Type::GetType(“System.IO.FileInfo”);
arrFiles = System.Array::CreateInstance(sysType, 1); //1 dimension array.
arrFiles = directoryInfo.GetFiles();
intTotalFiles = arrFiles.get_Length();
CodeAccessPermission::revertAssert();
for (intFileCnt = 0; intFileCnt < intTotalFiles; intFileCnt++)
//read directory.
interopPermission.assert();
fileInfo = arrFiles.GetValue(intFileCnt);
strFullFileName = fileInfo.get_FullName();
conFiles += [strFullFileName];
return conFiles;
