Dear all,
I got an error when firming plan purchase order.
The error is
Number sequence error when picking purchase order number.
Purchase number PO/14/000108 is already in use
What should i do ?
Thanks in advance
Regards
Dear all,
The error is
What should i do ?
Thanks in advance
Regards
Seems the PO number is already used.Have you tried finding this PO in your Purchaser order details?
If it is Test environment, you can go PO Number sequence and set the “Next” field to another number i.e., (Maximum available PO number in Purchase orders form+1)
Hi Santosh,
Thanks for your advice.
Actually the case already close.
In ax 2009 there are two sequence number , purchase and purchase order.
The purchase order is for confirmation and the purchase is use for creating the purchase order document.
The problem is in purchase sequence.
Thanks.
Regards
Rudy
