I get the following error message when trying to release or post a sales order.
Unit of Measure code must have a value in Sales Line; Document Type = Order Document No = 105440 Line Number = 2410000. It cannot be zero or empty.
Does anyone now how to fix this? Thanks.
Locate the line causing the problem and enter a unit of Measure code for that line.
Do you know how to find the specific line?
Did you try following the instruction in the message?
Thanks a lot for your help. I couldn’t work out how to find the line but the company who installed NAV for me just showed me. It’s easy when you know how. I’ve only started using NAV about 2 weeks ago and it’s a steep learning curve!
