When calculating a regenerative plan on a planning worksheet, we’re getting the " no routing line within the filter" error. There is a routing assigned to the item in question and it’s certified. What else should we be looking at?
There is a similar message when routing link codes are used in the routing but they are not referenced back to the BOM - do you have this scenario?
There was also a similar message with regards to routing when it is certified, which a service pack resolved, but you have got past this part!
