Hi Guys! What could be the problem? When I’m trying to acess invoices or orders I have that message "Invalid page number (5) for the tab control named ‘control1’ (InPage was set to 5 on the checkBox’BizTalk Purchase Order’) Thanks.
Have you checked that you have a name for page 5 for all languages in the PageNameML property of the tab control? I suspect that is what is causing the error.
I had this problem, when I calles the function: Translate -Export from a form with e.g. 5 Tabs; than, when I call this function in another database to import to the same form, but with 4 tabs only, I also get the message like you.
OK Thanks guys! Yes modification has been made on the PO ( addition of a new tab).
