Error message when running "Close Income Statement"
Hi everybody,
While running " Close Income Statement" for the FY 01 Jan 13 - 31 Dec 13, i got this error:
The transaction could not be completed because it will cause Inconsistencies in the G/L Entry table
Check where and how the CONSISTENT function is used in the transaction to find the reason for the error
Contact your system Administrator…
I followed these steps:
  1. Close inventory period
  2. Create new FY 2014
  3. Close FY 2013
  4. Run Close Income Statement
Any idea what might have caused this problem and how could be solved ?
Thanks in advance!
Uaja
Hi Uaja,
that’s a tricky one. Do you have an additional reporting currency enabled? The most probable cause that comes to my mind is a mishandling of additional reporting currency by the posting codeunit or additional logic. Anyway, that’s a case where you need an experienced professional (preferrably your NAV partner) to resolve the issue.
What you can do when you have a copy of your database to run tests on: Disable additional reporting currency, and run the close income statement again. This should give you a general journal for the closing of the income statment, which should post as expected. If that’s the case, then you have an additional reporting currency issue.
with best regards
Jens
Hi Jens!
Yes, the additional reporting currency is enabled.
I’d better consult with our partner and wait for their suggestions.
Thanks for your reply,
Uaja
