Error Message when opening table
Hi Friends,
I’m new to this technology Could anyone help me with this error message.
Actually, we would like to load budgets into SQL server database NAV is the front end of SQL.
we have table name Item Budget Entries in the Nav and in the SQL Server.
So when I was opening this table in the NAV it is throwing an error message like I dont understand what it means
Just I clicked on Form then I searched for table then clicke on Run then pop up below message
Welcome to DUG!!!
Any Customization on Table??
You are running the form not Table…
You should never load anything directly into SQL. When you do this none of the NAV code / business logic executes. I would highly recommend you get some NAV training before you start into things.
