HI ALL
when i try to open RETAIL CUSTOMER CARD form error message say
refrence to the member retail customer of the variable could not be solved
i think may some fields in some tables related to this form disabled
any help please
HI ALL
any help please
Kindly check your tables for any field addition or modification.
Open your from object designer and you can see the fields which has been changed .
thanks amol yes i have one modified field by repairing it the problem solved
thank you
Please check your Rights for the Roles
