error in workflow
“Incorrect parameter for the function SysDictEnum.value2Index”
i got this error while config the workflow configuration.
in workflow configuration for a template while modifying it is showing this error.
Can you elaborate it…
By doing what modification you are getting this error
like when - writing some instruction or modifying some field - which help in understanding your problem…
At what point in your config did you get the error? Is this a custom template or a standard template which you are using?
