I am Presently Using R2 in Microsoft Dynamics Nav.
I create a Form and I want to convert into that form to Page, but the error is showing,
I have attached the error message, Please see the error message, and kindly tell the solution and help for my report to do.
Where did you attach?
BTW, some classic properties are not supported in RTC so read the form properties which are supported and whoch are not before transforming
The error message is shown below, Please see the error message, and kindly tell the solution and help for my report to do.
Error Message:
"This message is for C/AL Programmers:
Could not create an instance of the OLE Control or Automation server identified by Guid={F9043C85-F6F2-101A-A3C9-08002B2F4F9FB}.
Check that the OLE control or Automation server is correctly installed and registered."
Did you Google that GUID? Looks like a Common Dialog Management type control to me.
