Error in tabel 18 Customer tabel.
Dear All,
I created a new column in the Customer table, after a while I deleted it from the Customer table but through the SQL Server. now I tried to delete it from Navision but I always get an error which says:
I will go crazy to delte this field ! but I canot, I canot even compile the tabel due too this field.
Can anyone help me. (I am using Navision 2009 Classic client)
Thanks in Advance
Clearly that you should never do that. Haven’t done that myself, but the next thing I would do is recreate the column on SQL Server and then try again.
I did already, and when I create it enforce me to create the column with default null values. and this Couse another problem. so even if I create the field in SQL with allowing Null values Navision does not except it.
Any other ideas ?
Any other ideas ?
I did it!
1- I created the field again in the SQL server (right click/design/create the field WITH <DATETIME,not null>.
2- went to Navision tabel 18, compile it. then I delted the field manually.
Thanks,Zayed
Congrats.
