Error in SSRS
I have duplicated Customer external statement report.When I run the report I am getting below error.
In \Classes\PrintMgmtDocType\getDefaultReportFormat class I have called my customized report.
In menu item also I followed the same as standard.
(C)\Classes\SRS_CustAccountStatementExtController\prePromptModifyContract - line 4
(C)\Classes\SrsReportRunController\startOperation - line 7
(C)\Classes\SrsPrintMgmtController\startOperation - line 14
(C)\Classes\SrsPrintMgmtFormLetterController\startOperation - line 14
(C)\Classes\SRS_CustAccountStatementExtController\main - line 6
Any solution for this?
Problem is solved.I generated Incremented CIL.
Hello Saju,
I am facing the same issue. However, when i generate incremental CIL from AOT I am facing this issue:
CIL generation: Line Number 85 - Source array was not long enough. Check srcIndex and length, and the array’s lower bounds.
in class: SalesInvoiceController\main (line 82)
any ideas?
Thank you.
